Terms
The terms listed below are related to the Guide Me aid and product. Throughout the guide acronyms have expanded terms for assistance.
| Term | Description |
| API | Application Programming Interface. |
| Coupon | See promotional code. |
| Current Hit | The Hit is currently being interrogated for matching data. |
| Dimension | A Dimension defines how data is segmented. |
| Dimension Group | Historical term, same as report group. |
| DMS | A system administrative function Discover Management Service or Discover Services Manager. |
| DNCA Server | The Discover Network Capture Application server. |
| Endpoint | Referred to in the SDK as the URL to which visitor session data is sent. |
| Event | A Discover component that executes, and optionally stores values, when criteria are met using Hit, STEP or Session Attributes. |
| HA | See Hit Attribute |
| HBR Server | Health Based Router. Discover routing / balancing server. |
| Hit | Term to describe the item line show in Replay that can include Request / Response data available for event building. |
| Hit Attribute | A Hit Attribute describes the format of the data identified within a session and available within the Response and Request document for event building. |
| Load Balancer | A software (can be hardware) component of the network that distributes data between downstream systems, for Discover this is typically the DNCA. |
| OoO | Out of Order. Typically relating to Hits within a visitor's session. |
| Pipeline | Pipeline defines the order in which Discover components are applied to data streams, for example visitor session data traversing through the Discover solution DNCA, HBR, Canisters and Reporting/Portal server. |
| Processing Server | The server responsible for processing events for visitor sessions. |
| Portal | See Reporting Server |
| Promotional Code | Text provided to visitor/customer, which may include numbers or non-alphabetical characters used to discount overall price paid online |
| Report Group | Assigned group of dimensions to provide segmentation. |
| Reporting Server | The server hosting business user dashboards / reports. |
| REQ | Request -- See Response/Request. |
| Response/Request | Visitor session payload data document or buffer. |
| RSP | Response -- See Response/Request. |
| Sandbox | An environment within HCL SoFy that provides access to a unique instance of Discover. |
| SDK | Software Development Kit. Often referred to as the discoverUI.js file. |
| SQL | Structured Query Language. Associated with the database server. |
| STEP Attribute | A JSON notated message available only in the Request document / buffer used for event building. |
| UIC | UI (User Interface) Capture. Same as the SDK foDiscover. |
