Removing the Linux® gateway support
You can use the Uninstall BigFix® Remote Control Gateway support for Linux task to remove the gateway support files from a Linux® computer.
To initiate this task, complete the following steps:
- Click in the navigation tree.
- Click Uninstall BigFix® Remote Control Gateway for Linux.
- In the Task pane, review the description and follow the
instructions in the Actions box to start the task.
- In the Take Action pane, in the Target tab, select the relevant option for determining which targets to remove the gateway support from.
- Click OK.
The gateway support files are removed from the selected targets.
Note: After the removal of the gateway support, some files might not be deleted automatically. The
files were created during the installation of the gateway component. The files are in the directory
/opt/ibm and
/var/opt/ibm/trc/gateway.
