Update the BigFix® Remote Control components
The Update node in the BigFix® Remote Control navigation tree provides subnodes that are operating system specific. Use the Update node to upgrade the components to a later version. To view a list of tasks that you can use to upgrade the components, select the relevant operating system node.
