Deploying the Linux® gateway support
You can use the Deploy BigFix® Remote Control Gateway for Linux task to install gateway support onto a Linux® computer.
To initiate this task, complete the following steps:
- Click in the navigation tree.
- Click Deploy BigFix® Remote Control Gateway for Linux.
- In the Task pane, review the description and follow the
instructions in the Actions box to start the task.
- In the Take Action pane on the Target tab, select the relevant option for determining which targets to deploy the gateway support on.
- Click OK.
Gateway support is installed on the targets that you selected when you ran the deployment task. The files are installed in the /opt/IBM/trc/gateway directory on the selected targets.
To use the gateway support, you must set up a gateway configuration for your environment. For more information about configuring the gateway, see the BigFix® Remote Control Administrator's Guide.
