Deploying the Linux® controller
You can use the Deploy BigFix® Remote Control Controller for Linux task to install the controller software onto a Linux® computer.
Note: If you are installing the controller on a Red Hat 6.0 64-bit computer the following extra
libraries, along with all their dependencies, must be installed: libXft.i686 libXmu.i686
libXp.i686 libXtst.i686.
To initiate this task, complete the following steps: Procedure
- Click in the navigation tree.
- Click Deploy BigFix® Remote Control Controller for Linux.
- In the Task pane, review the description and follow the
instructions in the Actions box to start the task.
- In the Take Action pane on the Target tab, select the relevant option for determining which targets to deploy the controller on.
- Click OK.
