CPU usage reaches 100% during installation or upgrade of a Bare Metal Server
- Problem description
When installing or upgrading BigFix Bare Metal Server on an BigFix relay, the CPU on that system reaches 100% usage for several minutes. This may downgrade system performance considerably and tasks running on the system might become unresponsive.
- Solution/workaround
This problem does not affect the outcome of the installation itself. To minimize the impact on system performance, you can plan the installation or upgrade of your Bare Metal Server in a timeframe during which the relay is not processing other time-critical activities.
