Adobe Flash removal from BigFix OS Deployment dashboards limitations
- Problem description
- OS Deployment dashboards can now work without Adobe Flash, however, with some limitations.
- Solution/workaround
- The following are some of the general limitations for all the OS Deployment dashboards
after Adobe Flash dependency removal:
- Adjusting column width in the tables are not supported.
- Changing the column positions in the tables are not supported.
- The table headers are not sticky to the top of the rows when the tables are scrolled down.
Scripting Environment Library dashboard
This dashboard is obsolete and is being deprecated. The Adobe Flash version of this dashboard continues to be available.
