Maintenance and Configuration tasks and Fixlets
Maintenance and Configuration tasks and Fixlets indicate actions that you must take to maintain your deployment. If a Fixlet or task in the list is disabled, it is not relevant to any computers in your deployment.
Click Maintenance and Configuration from the navigation tree and select a task or Fixlet. For each Fixlet, click the name and then click in the Actions box of the Fixlet window to deploy the appropriate action.
