Cannot capture/deploy Ubuntu 18.04 from/to VMware Virtual Machine Version 13 or later
Problem description
When you try to capture/deploy Ubuntu 18.04 from/to VMware Virtual Machine Version 13 or later a white screen appears. This issue occurs for both BIOS and UEFI firmware.
Solution/workaround
Using a VMware Virtual Machine Version earlier than 13 is recommended, alternatively the capture/deploy with resource Ubuntu 16.04 is also possible.
