Console freezes when importing a captured Windows image (.wim) file
Problem description
When you import in the Image Library a captured image that resides on a remote machine and click "Analyze", this operation might cause the console to freeze for some time, depending on the size of the .wim file and the network speed.
Solution/workaround
To avoid this problem, copy the image locally on the machine where your Console is installed and repeat the import operation.
