Capture fails if network boot is configured before disk in target boot sequence and PXE server is in the same network
Problem description
During a capture scenario for both BIOS and UEFI targets, if the network boot entry preceeds the disk boot entry and there is a PXE Server in the target's network, the capture action fails when the target performs a PXE boot on the network instead of loading WinPE. The action status might remain running or change to complete.
Solution/workaround
Check the boot sequence at the target, and eventually change the configuration so that the target boots from disk instead of performing a network boot with a PXE server.
