Copy image settings error on manual driver bindings
- Problem description
- From the Image Library dashboard, when you attempt to copy image settings to a target image from which all manual driver bindings were previously removed, the following error message is displayed:
Selected image already contains manual driver binding grids. The operation cannot be completed
- Solution/workaround
- Sometimes, the data store is not erased even after drivers are manually removed. To avoid this error, complete the following steps for the target image for which the copy settings operation received the error message:
- Open the Driver Library dashboard.
- Click the Bindings tab.
- Select the target image and the computer model from the list.
- Select the bound driver and click Edit.
- Select the Auto radio button to disable manual driver binding and save your changes.
