Setup
The Wake-on-LAN Medic utility is a process that runs on the BigFix server. This utility manages Wake-on-LAN scheduling and keeps Last Man Standing computers awake.
You must enable the Wake-on-LAN Medic so that Wake-on-LAN features work correctly.
Use the Setup task to install the latest version of the Wake-on-LAN Medic utility. Click this task from the navigation tree. When the Task window opens, review the description and click in the Actions box to initiate the utility.
Note: Ensure that REST API is set up correctly to avoid errors and for the Wake-on-LAN Medic Utility to function properly.
  • If Wake-on-LAN Medic utility is not enabled, the Enable Wake-on-LAN task might not be relevant.
REST API is supported by BigFix server version 9.0 and later.
BigFix Task panel for Enable Wake-on-LAN Medic showing the task description explaining the utility installs the WoL Medic process on the BES server for wake scheduling and Last Man Standing management, file size 3.18 MB, with an Actions link to enable the utility
