Power consumption over time
The Power consumption over time report charts the average computer power consumption over a specified time period, and displays cost or savings compared to a baseline cost based on the start date.
Use this report to review historical savings and progress of power management policies. You must have Historical Power Tracking enabled to use this report.
Note: If you select the current date as the End Date, the report might take significantly longer to generate because the current date has not yet been pre-calculated.
Power Consumption Over Time report configuration screen showing report grouping policy set to OS, report groups for Windows versions selected, results filtered for Laptops and Desktops, and consumption period set to Last 7 Days
Power Consumption Over Time report output showing a line chart of daily cost per computer for Test Subnet from June 8 to June 15, 2010, with a summary table showing total consumption of $1.59 and savings of $0.15 compared to start date
