Power Management Calculations Documentation
Access the reference documents that describe the formulas used by BigFix Power Management to calculate power consumption, savings, and efficiency, including an explanation of differences between the deprecated and revised Power Consumption Over Time calculations.
BigFix Lifecycle Power Management addresses the challenges of managing power in distributed environments with a policy-driven power management solution.
Refer to the Power Management Calculation Document to find out the formulas used by Power Management's key features.
You can also refer to the Difference in the Calculation of the Earlier and Revised Power Consumption Custom Report to see the difference in the calculation used in the deprecated and revised version of the Power Consumption Over Time web report.
