Guidance Tool Symbols
Use the guidance tool to display action symbols on the target screen to indicate to the target user which mouse button that they should press and what action should be taken. The following actions are available.
- Cancel
- to cancel the mouse action you just performed. A guidance symbol is not placed on the target screen.
- Move
- to move the target mouse to this particular point on the screen.
- Single click
- to click the target mouse button once.
- Double click
- to click the target mouse button twice.
- Drag Start
- to click and hold the target mouse button and start to drag the mouse.
- Drag Stop
- to continue to drag the mouse then release the mouse button at this point.
The following table shows the relevant actions and their
symbols.
Single Click Left button | Single Click Right button | Double Click Left button. | Double Click Right button. | Drag Start | Drag Stop |
The mouse button that you click determines which mouse button on the guidance symbol is shaded. This will indicate to the target user which button to press. The following table gives examples of the symbols showing how each mouse button action will look.
Left button | Middle button | Right button |
