Transferring files and directories
File Transfer Mode is a connection mode that you can use to remotely connect to a target. When connected in File Transfer Mode you can view the target's file system and transfer files and directories from the controller machine to the target and vice versa. There is also an option to delete files and directories and create a directory.
When the connection is established the controller window displays two panes. The pane on left shows the controller’s file system, the pane on the right shows the target's file system.
