Recovering when the program is not running
If, after typing the Remote Control URL in your browser, the logon page does not display, you can check to see if the Remote Control-server service is running on the BigFix® Remote Control Server by doing the following :
- Within Control Panel, select Administrative Tools then Services
- Scroll down to the entry for Remote Control- server and check if its status is Started
- If not, right-click this entry and select Start
- If the status is Started, right-click, select Stop then restart it again as above
- Type the Remote Control URL in your browser. The logon page should be displayed.
