Manage the Unattended Target environment
Learn how to manage the Unattended Target environment.
The Unattended Status Cache
The information about the Target Heartbeat and the Unattended Target Status is stored on a volatile cache on the server for performance reasons. The actual Unattended Target Status is visible from the Target Status page (after selecting the single target), from the Deployment Status Dashboard from the Server log file or from the Target List on the Controller.
The volatile nature of the cache implies that if you restart, the server starts to populate with real-time information as they are processed on the server.
You can set the rc.dashboard.preload.on.startup option to preload
the cache at server startup. In this case, the status of the preloaded target
appears as Unknown until the target reaches the server again.
Call Home v/s Heartbeat
A Managed Target performs a
Call Home every rc.heartbeat_timeout minutes.
An Unattended
Target perform a Call Home every rc.heartbeat_timeout minutes and a
Heartbeat (also named Pulse) every
rc.unattended.heartbeat.interval.minutes.
The target
asset information is updated on Call Homes. That information includes
LAST_UPDATE time stamp, IP ADDRESS LIST,
BROKER. For an Unattended Target, this information indicates
the last Call Home information.
The information about the target Heartbeat and the Unattended Target Status is stored on a volatile cache on the Server.
An Unattended Target can be recognized by the presence of a broker in theBROKER column of the All Target
View.Heartbeat Interval and Offline Grace
An
Unattended Target contacts the server every
rc.unattended.heartbeat.interval.minutes to report its status
and to check if there is any pending session request.
When you initiate a
Remote Control Session with an Unattended Target, the
rc.unattended.heartbeat.interval.minutes also indicates the
maximum amount of time you need to wait before the session is established.
rc.unattended.heartbeat.offline.grace indicates how many
missing target heartbeats are allowed before the target is considered
Offline.Controlling Unattended Session Timeout
It is possible to control the timeout value of the Unattended Target sessions.
When starting sessions from the Start Session entry
from the Remote Control Server, the controller must be started within 15 minutes
(the same as in standard Managed sessions). You can control this timeout value using
the rc.unattended.controller.token.minutes property.
When
operating via the target list (from the Start Unattended
Session either via the Remote Control Server or via the Lite Web
Portal), the controller is authorized to operate for 60 minutes from the initial
session request. If the controller is closed, a new start session is required. You
can control this timeout value using the
rc.unattended.targetlist.token.minutes property.
rc.unattended.targetlist.token.minutes, you must
consider the operating environment (either via portal or via server interface) as well
as what other security feature you are planning to adopt. Using a higher timeout value
requires less session restart. If Controller
UUID or Two Factor
Authentication is used, you must consider increasing this timeout
value.Target Groups
Unattended Targets can be assigned to a Target Group during initial
registration or at every Call Home in accordance with the same
rules that apply for Managed Targets.
If you are using rules based on IP address and you have indicated
rc.tmr.at.registration,
rc.tmr.at.every.callhome, or
rc.tmr.at.triggered.callhomes and the
UnattendedInternetAccess is set to Auto,
the target might change its group depending on target location. Review your rules
and ensure the targets are assigned to the desired group.
Using the Asset Tag
You can use the
Target Asset Tag to add notation to a target or a group of
targets to make it easier to search for targets.
Controlling Log Content
As you operate with an increasing number of targets, the log information that is produced can be impractical.
You can set the Broker log level to 1.
trc.properties to control
logging functions.- Set
rc.unattended.log.incoming.heartbeatto False to prevent every Unattended Target heartbeat to produce a log entry. - Set
rc.unattended.log.heartbeat.trendto True to produce a periodic summary in the Server Log File on how many heartbeats were received in the lastrc.unattended.heartbeat.interval.minutesinterval. The same information is available in graphical form from the Deployment Status Dashboard.
rc.unattended.log.cache.report produces a periodic
summary in the Server Log File on the Status of
Targets as known to the server. On each periodic summary, a list of targets
for each status is included in the summary based on the status of the respective
property in the Unattended Target - Log cache entries at cache
report section.Debug Options
The following
properties are available in the Unattended Target - Tuning and debug
options section of the trc.properties.
You must use those properties following the indication of the HCL Support Team.
The rc.unattended.force.guid.check enables extensive
verification of target information at Heartbeat time. This option must be used if
Targets in Error status are noticed.
rc.unattended.log.timing.records and
rc.unattended.log.timing.completed provide processing time
information on the Server Log File to collect performance
information. The produced log file must be provided to the HCL Support team for
investigation.Monitoring the Unattended System Health
When the Unattended Target Support is enabled, the Deployment Status
Dashboard provides a real-time status view of the targets and broker
status that is based on the Unattended Status Cache.
BrokerList. The target connects the first broker that
responds to the request. Operating with more than one broker hence produces a load
balancing and redundancy effect.
