Configure target properties
When a target takes part in a peer to peer remote control session, its properties determine what functions are available during the session. Target properties can be configured by creating and running a target configuration task in the BigFix® console. For more information, see the BigFix® Remote Control Console User's Guide. You can also edit the target properties manually. To edit the target properties, you must have administrator rights. Enter your admin password when you are prompted.
Editing the target properties on a Windows™ target
  1. On a 64-bit system, all the 32-bit registry keys are under the Wow6432Node key. For example: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\BigFix\Remote Control\Target
    On a 32-bit system, go to HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Remote Control\Target
  2. Right-click the required property and select Modify
  3. Set the required value and click OK.
  4. Restart the target service.
Editing the target properties on a Linux™ target
  1. Edit the trc_target.properties file.
  2. Modify the required properties.
  3. Save the file.
Editing the target properties on an BigFix® Remote Control Target for macOS
To edit the target properties, complete the following steps:
  1. Open the Terminal.app.
  2. To modify a property, enter the following command.
    sudo defaults write /Library/Preferences/com.bigfix.remotecontrol.target.plist Keyword Value
    Where Keyword is the property name and Value is the value for the property. For example,
    sudo defaults write /Library/Preferences/com.bigfix.remotecontrol.target.plist LogLevel 4
  3. Restart the target.
    • For BigFix Remote Control version 10 update 6 or earlier
      1. Click Remote Control Target > Quit Remote Control Target
      2. Open the Remote Control Target app
    • For BigFix Remote Control version 10 update 7
      1. Enter sudo launchctl unload /Library/LaunchDaemons/RCTargetDaemon.plist
      2. Enter sudo launchctl load /Library/LaunchDaemons/RCTargetDaemon.plist
After you modify properties, you can type the following command to see a list of current property values.
defaults read com.bigfix.remotecontrol.target.plist
You do not need administrator rights to run the read command. Therefore, sudo is not required at the start of the read command.
