Default Shift Management
This screen enables user to define the default shift timings, it’s validity and week off days for any time zone.
  1. Click on Roster Management → Default Shift Management.
    Figure 1. Default Shift Management
  2. Select the time zone for which the start time, end time, week off days and duration need to be set by default.
  3. Select the shift interval.
  4. Select start time, week off days and duration and click update button. The alert below gets generated.
    The End Time will be disabled and auto populated by adding the default interval, in the Start Time, defined for that time zone.
    Figure 2. Success Message
    The default shift for any time zone will appear while applying shifts for any user, if any previous shift for the user doesn’t exist.
