Using Intel vPro with Wake-on-LAN Medic to wake up endpoints
Follow these steps to setup and schedule endpoints to wake up using the BigFix Wake-on-LAN Medic utility with Intel vPro.
- Subscribe to the latest versions of one of the following sites:
- BES Support site
- Power Management site
- BigFix server requires .NET Framework 2.0
- Enable the Wake-on-LAN Medic utility. For more information, see Enable Wakeup.
- Target computers require Intel AMT 3.0 and later versions
- If Intel Setup and Configuration Servers (SCS) will be used (optional), use SCS Server version 7.0 or later
Note: Ensure that RESTAPI is set up correctly to avoid errors and for the Wake-on-Lan Medic Utility to function properly. RESTAPI is supported by BigFix server version 9.0 and later.
You can use Intel vPro with the BigFix WoL Medic utility to wake up endpoints. BigFix Power Management uses policies to perform wake-on-LAN. The policies can be set to wake specific endpoints at specific times and to use vPro.
When the policy is executed, the BESWolMedic.exe utility is invoked to query the applicable endpoints and to send WOL packets.
When the vPro option is enabled, a utility called amtpowercmd.exe uses vPro after successful authentication to send the WoL signal over HTTP to wake up the applicable endpoints.
These steps apply to infrastructures with or without Intel SCS. It is assumed that the vPro infrastructure is set up.
- Set up the registry values.
- With SCS
- For x64
- "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSServer"Note: This value is either the host name or the IP address of the server.
- "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSUsername"
- "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSPassword"
- For x86
- "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSServer"Note: This value is either the host name or the IP address of the server.
- "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSUsername"
- "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSPassword"
- Without SCS
- For x64
- "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\ BigFix\EnterpriseServer\MFSConfig\PowerWoLvProUsername"
- "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\ BigFix\EnterpriseServer\MFSConfig\PowerWoLvProPassword"
- For x86
- "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLvProUsername"
- "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLvProPassword"
Note: If you do not use SCS, ensure that the credentials are the same on each endpoint to avoid wake up failure. - With SCS
- From the BigFix console, select the vPro option in
the wake-on-LAN policy.
- Go to the .
- Create a new policy or select an existing policy.
- Select Use Intel vPro technology along with BigFix WoL to wake these computers.
- Click Create Policy for new policies or save the change, for existing
policies.
For more information about using the Schedule Wake-on-LAN wizard to create and maintain scheduled wake-ups, see Schedule Wake-on-LAN.
