Power Management settings
The Power Management settings report displays the percentage of computers with enabled power management settings on a given day and allows for comparing improvements between different days. Enabling historical power tracking is necessary for the comparison feature to function, and selecting the current date for comparison may result in longer report generation times due to pre-calculated data for previous dates.
The Power Management settings report shows the percentage of computers that have power management settings enabled on a specific day. It can also be set to compare the improvements between two different days. The comparison function requires that historical power tracking is enabled.
Note: If you select the current date as the compare against
date, the report might take significantly longer to generate because
previous dates are pre-calculated.
