Power consumption over time
The Power consumption over time report illustrates the average computer power consumption over a defined period, comparing costs or savings against a baseline cost from the start date. It is beneficial for assessing historical savings and monitoring the effectiveness of power management policies, requiring Historical Power Tracking to be enabled for access.
The Power consumption over time report charts the average computer power consumption over a specified time period, and displays cost or savings compared to a baseline cost based on the start date. Use this report to review historical savings and progress of power management policies. You must have Historical Power Tracking enabled to use this report.
Note: If you select the current date as the End Date, the report might take significantly longer to generate as previous dates are pre-calculated.
