Model Power Savings
This report helps calculate potential power savings by applying different power profiles to your deployment based on current usage patterns, allowing for the creation of what-if scenarios for implementing power policies. The results are based on the actual power state history of each agent over the last two weeks, providing an accurate projection of potential savings.
This report calculates how much power you can lose or save if you apply different power profiles across your deployment based on your current usage patterns. You can use this report to formulate what-if scenarios for potential savings by implementing various power policies. By default, the results in this report are based on the actual power state history for each agent for the last two weeks. These results are expected to be an accurate projection of power savings.
