Power Management Daily Activity State breakdown
The Power Management Daily Activity State breakdown report provides a breakdown of average daily activity states such as Active, Idle, Standby, and Powered off. It enables users to evaluate power policy changes, identify areas for power savings, and compare improvements over different days, requiring historical power tracking to be enabled. Selecting the current date for comparison may lead to longer report generation times due to pre-calculated historical data.
The Power Management Daily Activity State breakdown report displays a breakdown of the average day by activity state. The activity states are Active, Idle, Standby, and Powered off. You can use this report to evaluate changes you make to your power policies. For example, if many computers have high idle times, you set a Standby power policy to save significant power. It can also be set to compare improvements between two different days. The comparison function requires that historical power tracking is enabled.
Note: If you select the current date as the compare against date, the report might take significantly longer to generate, as previous dates are pre-calculated.
