Downloading by using Java Web Start
The on-demand target is installed and started automatically by using Java™ Web Start when the target user is using Internet Explorer and ActiveX is disabled. The target user can also select the Java Web Start installation method if the ActiveX, Firefox, or Java Applet installation methods fail.
The target user must follow
the instructions on the page. If the installation process does not
begin, they can also click Start on the launching
page. If a prompt to run the application is displayed, they must click Run to
start the installation process. If a User Account Control prompt
is displayed, they must click Yes..
Note: If Java is not installed on the target
computer, the user is given the option to download and save the JNLP
file. However, the system is unable to run the file.
If the Enable user acceptance for incoming connections policy is enabled for the session, the target user is asked to accept or refuse the session. If they select Refuse, or do not accept in time, the session does not start. If the target user selects Accept, the session starts. Any errors during the installation are displayed and the session does not start. Errors are written also to a log file.
