Frequently asked questions
What is the definition of an on-demand target?
An on-demand target is a target that is temporarily installed so that you can start a remote control session with a system that is on the internet. The session is managed by policies that are set on the IBM® BigFix® Remote Control server and the target software is deleted when the session ends.
What is the definition of an unregistered target?
- An on-demand target.
- A system that has the target software installed, the Managed property is set to No, and the BrokerList property is configured with a list of brokers.
I have my own website, how can I provide access to the on-demand target portal?
You can integrate the web page into your own site by creating a static portal or a dynamic portal. For more information about creating a custom portal, see Creating a custom landing page.
During a remote control session, why does my screen freeze with a message displayed and the session pauses temporarily?
- When Windows™ is installed on the target system
- A User Access Control prompt is displayed on the target system.
- The target system has Fast user switching enabled and another user logs on.
- The target screen is locked and the target user must unlock it.
- When Linux™ is installed on the target system
I have saved a recording of an on-demand session on my computer, how can I play it back?
You must get a URL for a web page from your helpdesk agent. When you access the web page, the IBM BigFix Remote Control player is downloaded and started. Use the player to play your recording file. For more information about saving and playing back a recording, see Saving a session recording on the on-demand target.
