You can add extra input fields to the default web page
that is used during the process of downloading and temporarily installing
the target software.
IBM® BigFix® Remote Control
provides a default web page that has a mandatory connection code field. You can edit server
properties to add extra input fields to this web page. However, if you change the design or behavior
of the page, the customization is not automatically maintained if there is a server upgrade. To
create custom fields, complete the following steps:
- Log on to the server UI with a valid admin ID and password.
- Click .
- Select ondemand.properties.
- Enter values for the custom field.
- ondemand.custom.field.x.label
- Enter the display name for the field. The text that is entered
for the label is displayed on the default web page.
- ondemand.custom.field.x.required
- Set a value to determine whether this field is a required field.
- True
- The target user must enter information in the input field.
Note: When
you set the value to true you must also define a value for the label
field, otherwise the field is not displayed.
- False
- The target user can optionally enter information in the input
field.
For more information about the field definitions, see
OnDemand properties file.
- Click Submit.
- Click
The custom fields are displayed on the web page that is used to start the process for
downloading and temporarily installing the target software. To add new properties, you must manually
edit the properties file. After a manual edit, you must click . For more information about new property values, see OnDemand properties file.
