Configuring a dynamic custom web portal
You can integrate the on-demand target function into your own website by configuring a dynamic web portal. This type of integration allows your website to communicate with the IBM® BigFix® Remote Control server through a set of service URLs.
- To submit custom session data to the IBM BigFix Remote Control server, so that it can be saved to the server.
- To validate the connection code, to check it before the on-demand target application and delivery plug-ins are downloaded.
- To retrieve the broker environment configuration dynamically and avoid having to manually edit the properties file. For example, when the set of brokers changes, or a new trusted certificate is added.
Many different technologies can be used to implement a dynamic website. Details cannot be provided about how to achieve the required function because the necessary steps are different depending on the chosen underlying technology.
To configure a dynamic portal, complete the following steps:
