You can integrate the on-demand target function into your
own website by configuring a static web portal. This type of integration
requires you to copy a set of resources from the default portal on
the remote control server to your external website. The website is
used as a static portal on which to run on-demand sessions.
The term static refers to the content provided by the web server that does not change
unless the files themselves are edited in the web server system.The set of resources that are
required to be copied to your website, are the files for the plug-ins and the on-demand target
application. These files are copied to your website to allow all the files that are required to
start an on-demand session to be downloaded from there.
The drawback of this approach is that
there is no communication between the static portal and the internal remote control server.
Therefore, it does not allow for providing custom data, or to verify the connection code before the
remote control session starts. Because the configuration is also static, the connection code must be
provided after the on-demand target is started.
The prerequisite for configuring a static
portal is to have a web server that provides content through the internet. You must have permissions
on the web server to be able to add and edit content, and knowledge of web technologies.
To
configure a static portal, complete the following steps:
Go to the following directory on the remote control server:
RC_SERVER_INSTALL_DIR\wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\ondemandWhere:
RCSERVER_INSTALL_DIR is the IBM® BigFix® Remote Control server
installation directory.
Copy the 9.x.x.<version> directories to an \ondemand
directory on your own website. The directories contain the ODTJPlugin.jar,
ODTIEPlugin.cab, odtffplugin.xpi, and
TRCPlayer.jar files. One of the directories contains a
lnx32, and win32 directory. The contents of the
directories must also be copied.
Create a configuration file.
The configuration file must contain the details of the available brokers. Specify the broker
host names and ports in a semicolon separated list. It also contains a list of certificates that can
be used to verify that the certificate that is presented by the broker can be trusted. Save the file
with extension .properties.
For example,
config.properties, which contains the following
entries.
BrokerList=rcbroker.example.org:8881
-----BEGIN CERTIFICATE-----
Base64 encoded certificate data
-----END CERTIFICATE-----
where:
Base64 encoded certificate data is the certificate data for the specific
certificate. You can copy the certificate data from the
IBM BigFix Remote Control server. You must
have a BEGIN CERTIFICATE and END CERTIFICATE section for each certificate that you
add.
Select
Select the certificate.
Select Edit certificate.
Copy the certificate text to the configuration file.
- Create HTML pages for each installation
method that can be used to start the on-demand target.
- ActiveX control
- The HTML page that is used to provide the ActiveX control installation mechanism must contain a
short segment of JavaScript™ code for starting the
applet. It also contains an <object> tag to import the ActiveX control. The
following example uses a configuration file that is named config.properties and
web server rcweb.example.org. You must change the paths and file names to match
your environment. In the <head> tag, you must add the following elements to
include necessary JavaScript code.
<script type="text/javascript">
function autoLaunch() {
var ctl = document.getElementById('OnDemandCtl');
ctl.LaunchOnDemand("",
"http://rcweb.example.org/ondemand/config.properties");
}</script>
The <body> element of the page must contain the following elements.
<div style="height:200px">
<object id="OnDemandCtl"
classid="CLSID:E8A8645D-629A-4E27-B66C-67AE140C76A4"
codebase="ondemand/VERSION_NUMBER_1/ODTIEPlugin.cab#VERSION_NUMBER_1" >
</object>
</div>
You
must replace VERSION_NUMBER_1 with the version number of the folder that you
copied the ODTIEPlugin.cab file to in step 2. For example,
codebase="9.1.0.0020/ODTIEPlugin.cab#9.1.0.0020".
If the target user is using Internet Explorer
and ActiveX is supported and enabled, the on-demand target application is automatically downloaded
and started when the HTML page is accessed.
- Firefox plug-in
- The HTML page that is used to provide the Firefox plug-in installation mechanism must contain
the following content. The server must be configured to associate .xpi files
with the Mime Type: "application/x-xpinstall". The method for configuring the Mime Type varies
depending on the web server that you are using. The following examples use a configuration file that
is named config.properties and web server
rcweb.example.org. You must change the paths and file names to match your
environment. Copy the ondemand.js and ondemandff.js files
from the ondemand directory in the IBM BigFix Remote Control server to the
ondemand directory on your own website. In the <head>
tag, you must add the following elements to include necessary JavaScript code.
<script type="text/javascript" src="ondemand/ondemandff.js"></script>
function checkForPlugin() {
ondemandFFPlugin.checkPlugin();
</script>
The <body> tag of the page must contain the onload
attribute with the following content "setTimeout(checkForPlugin, 2000);". For example,
<body onload="setTimeout(checkForPlugin, 2000);">
The
<body> tag must also contain the following elements.
<form name="downloadPluginWin32" id="downloadPluginWin32"
action="ondemand/VERSION_NUMBER_1/win32/odtffplugin.xpi" method="get"
onSubmit="return true;"></form>
<form name="downloadPluginLnx32" id="downloadPluginLnx32"
action="ondemand/VERSION_NUMBER_1/lnx32/odtffplugin.xpi"
method="get" onSubmit="return true;"></form>
<object id="odl-params">
<param name="config_url"
value="http://rcweb.example.org/ondemand/config.properties"/>
</object>
<object id="odl-plugin-handle">
<param name="odt-plugin-version" value="VERSION_NUMBER_1">
</object>
Replace
VERSION_NUMBER_1 with the version number of the folder that you copied the
odtffplugin.xpi file to in step 2. For example, action="9.1.0.0020/odtffplugin.xpi.
If the Firefox plug-in and JavaScript are enabled when the target user is using a Firefox browser,
the on-demand target application is automatically downloaded and started when the HTML page is
accessed.
- Java™ Applet
- The HTML page that is used to provide the Applet installation mechanism must contain the
following content in the <body> element of the page. The following example
uses a configuration file that is named config.properties and web server
environment.
<applet archive="VERSION_NUMBER_1/ODTJPlugin.jar"
code="com.ibm.uk.greenock.odt.plugin.app.ODTJPluginApplet">
<param name="codebase_lookup" value="false" />
</applet>
You
copied the ODTJPlugin.jar file to in step 2. If Java is enabled
in the target user's computer, the on-demand target application is automatically downloaded and
- Java Web Start
- The Java Web Start installation mechanism does not require
an HTML page. It requires that a JNLP file is created. The JNLP file can be linked directly from
another HTML page. When the page is accessed, it activates the Java Web Start delivery plug-in for the on-demand target application, which is downloaded and
started automatically.
Use the following sample content to create the JNLP file. The example uses
environment. Change 9.x.x in the title to the relevant target version.
<?xml version="1.0" encoding="utf-8"?>
<jnlp spec="1.0+"
codebase="http://rcweb.example.org/ondemand/VERSION_NUMBER_1/">
<information>
<title>IBM BigFix Remote Control Launcher for
On Demand target 9.x.x</title>
<vendor>IBM</vendor>
</information>
<security><all-permissions/></security>
<resources>
<j2se version="1.4+"/>
<jar href="ODTJPlugin.jar"/>
</resources>
<application-desc>
<argument>--config_url</argument>
<argument>http://rcweb.example.org/ondemand/config.properties</argument>
</application-desc>
</jnlp>
Replace
Note: You can add the URL to the JNLP file to the custom HTML pages as a fallback URL. If the
on-demand target fails to start when the target user chooses another installation method, they can
click the link. The target is downloaded and started by using the Java Web Start installation method.
- Optional: Create an HTML page that the target
user can access to start the IBM BigFix Remote Control player.
The player can be used to play back a saved recording of an
on-demand session. The page must contain the following element to
start the player. The following example uses a web server
rcweb.example.org.
You must change the paths to match your environment.
<applet id="player" width="100" height="100" align="middle"
archive="VERSION_NUMBER_1/TRCPlayer.jar"
code="com.ibm.uk.greenock.ayudame.playerui.RecorderApplet">
<param name="codebase_lookup" value="false">
</applet>
You must replace
TRCPlayer.jar file
to in step
2.
For example, http://rcweb.example.org/ondemand/9.1.0.0020/TRCPlayer.jar.
