Multi-tenancy setup for the Self Service Portal
Setting up a multi-tenant environment with the Self Service Portal (SSP), the SSP must be manually configured. The Trusted Service Provider (TSP) must also be manually configured to allow communication to the SSP.
The multi-tenancy installation process is the same as with a regular SSP deployment. From this point on, the rest of the configuration steps are completed outside of content. This configuration is completed by using a command line utility in <Program Files>\BigFix Enterprise\Management Extender\MDM Provider\utils\ssp.bat.
Open the command line with administrator privileges to the MDM Provider\utils folder for any of the configuration steps.
