Registering computers through the Self Service Portal
Endpoint users must register computers to themselves from
the Self Service Portal by using a personal identification number
(PIN). Use this procedure if you are an endpoint user and want to
register a computer to your account from the Self Service Portal.
Ensure that you have the latest version of the client dashboard.
If you enabled the Mobile Device Management Self Service
Portal, click Available Software tab.
Click Add a Computer or the computer
icon.
Figure 1: Add a computer
Locate the PIN of the computer that you want to register.
Windows computers
You can view the PIN from the bottom of the Available
Software tab of the client dashboard. Figure 2: Web portal registration PIN in the Client Dashboard for Software
The client dashboard is also known as the IBM BigFix Support
Center. For more information about this dashboard, see Client Dashboard for Software Offers.
Earlier versions of the client dashboard do not display the PIN.
You can locate it at HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\EnterpriseClient\SSP_PIN.
Mac and Linux computers
You can locate the PIN at /var/opt/BESClient/SSP_PIN.
Note: If you cannot locate your PIN, contact your IT
administrator.
Enter the PIN in the Self Service Portal.
Figure 3: Enter the PIN
When the computer registration is complete, the computer is
added in the Self Service Portal.
