Login prompt not displayed on RedHat Enterprise Linux (RHEL) 7 after Bare Metal deployment
- Problem description
- After a Bare Metal deployment on a RedHat Enterprise Linux Server version 7 (RHEL 7), the login prompt is not displayed on the target, and the following message is issued:
sda3: WRITE SAME FAILED. Manually zeroing - Solution/workaround
Press Enter on the target and the login prompt is displayed. This error can occur on VMWare targets only.
