Deployment from media fails because some files are not read correctly
- Problem description
Deployments using offline or netboot media can fail because some files on the media are not read correctly. For example, this error can occur if you are using the media for deployments on older hardware or operating systems that might not support the current UDF format (UDF version 1.02) used to create the media.
- Solution/workaround
A possible solution is to create the deployment media using the old ISO9660 format, To use this format, you must add a computer setting on the Bare Metal Server that you selected for the media creation. Locate the Bare Metal Server in the Subscribed Computers view, then edit the computer and add the following custom setting:
Set the value toBAREMETAL_USE_ISO9660
TRUE
