RBO entry causes Linux targets to reboot repeatedly during capture or reimage
- Problem description
- During a capture or a reimage deployment , a new entry is added to the linux boot loader of the system being captured or reimaged. If the capture or deployment fails, the RBO entry might not be removed on the Linux target. This causes the target to reboot repeatedly. To remove the entry manually, complete the steps described below.
- Solution/workaround
- Download one of the following depending on the Linux operating system architecture:
- Make it executable (
chmod +x rbagent.linux). - Download rbagent.pak http://software.bigfix.com/download/osd/rbagent.pak.
- Run the following command:
rbagent.linux -o rad-setlinuxboot removeconf
