Sometimes, the data store is not erased even after drivers
are manually removed. To avoid this error, complete the following
steps for the target image for which the copy settings operation received
the error message:
- Open the Driver Library dashboard.
- Click the Bindings tab.
- Select the target image and the computer model from the list.
- Select the bound driver and click Edit.
- Select the Auto radio button to disable
manual driver binding and save your changes.
From the
Image Library, select the target
image again and click
Copy Settings from... to
repeat the operation.
