Assigning target groups to other target groups.
Use the Manage Group Membership function to assign target groups to other target groups thus creating a group hierarchy. Target groups are assigned the permissions and policies of the direct target groups they are a member of. These permissions are known as their standard or normal set of permissions. For more information about how policies and permissions are granted by the Policy Engine, see How policies are determined for a remote control session.
To add target groups to target groups, complete the following steps:
Choose the appropriate method for displaying the target groups.
- Select from the Actions list on the left.
Select the target groups that you want to add the target groups to. Some target groups in the
list might have a plus sign in front of their name which can be expanded to show other target
groups. If you selected multiple target groups in step 1, select one of the following options.
- replace current group membership
- add to current group membership
- delete from current group membership
- Click Submit.
