Cleanup non-reporting targets
As the number of targets present in the database is a factor to determine license compliance, it is important to clean up the database periodically and remove non-reporting targets.
dbcleaner
process and controlled by the target.offline.max.age property in
trc.properties. With this property, you can configure the target
cleanup to run automatically or indicate for how long a given offline target can be kept
in the database.When the value is set to 0, no offline target cleanup is performed. The properties indicate in days for how long a target that is no longer calling home is kept in the database.
If you want to perform automatic offline target cleanup specify a value that suites your deployment.
