Manage custom reports
There are a number of actions that you can perform when you select a custom report from the list.
- Edit Custom Report and Access
- Change details about the custom report and also change the group access to this report by selecting or deselecting groups in the list.
- Remove my access
- Remove custom reports from your Custom Reports menu.
- Delete Custom Report
- Deletes the selected custom reports.
