Create a Custom Report
Custom reports are created by a Super User or Administrator and are useful for generating reports that specifically meet the needs of their environment. To generate a custom report, a customized SQL query is run against the database and its output is displayed on screen.
Custom reports can be created in multiple ways:
- By sorting, filtering, or removing columns from a generated report, to meet your own requirements.
- By directly editing the SQL that is used to generate the report. You must understand how to use
SQL to complete this method.
- By creating a new report by using the Edit SQL feature to build a query by adding required
tables and columns. This method can be done in multiple ways:
- Select to create a new report.
- Use an existing report as the basis for the new report.
- By adding database tables and columns to existing reports.
