Creating a new report by using an existing report
You can create a custom report by using the Edit SQL feature on an existing report.
Generate the base report by selecting the required report from the menu.
For example, to use the All Targets report as the base report, complete the following steps:
- Select .
- Click Edit SQL, on the upper right of the screen.
- Follow from step 3
