Obtaining the gateway log files
The gateway log file can be used for debug purposes when you have an issue in your environment and gateways have been configured.
The name of the log file is TRCGATEWAY-hostname-suffix.log where hostname denotes the computer name or host name of the system hosting the gateway and suffix denotes the date and time, depending on which rotation and rollover settings are being used. For more information about the log, see Logging gateway activity.
The log file is located in the following directories:
- Windows® systems
\ProgramData\BigFix\Remote Control\Gateway
- Linux® systems
- /var/opt/bigfix/trc/gateway
