Errors when you are using the Java applet method of installation
- Bad URL:{0}
- When a malformed URL is entered by the target user. For example, Bad URL: htp://example.com/#123456.
- Bad server response for {0}: Response code {1}
- When an invalid URL is provided. For example, Bad server response for http://example.com/index.jsp?conncode=0000000:Response code: 404.
- Unable to determine host architecture
- The Java Applet is unable to determine whether the architecture of the target computer is 32-bit or 64-bit.
- Error running {0} -c={1} -l={2}
- When the Java Applet fails to start the on-demand launcher. For example, Error running /tmp/trc_odt-abc-123.exe -c=http://configurl -l=C:\Users\tgtuser\trc_odt_trace_20130510_131023.log
- IO Error downloading from {0}
- When a read or write error occurs while the ODL, or the configuration package is downloaded from the server. For example, IO Error downloading from http://configurl.
- Unable to open the log file for writing
- When the Java Applet is unable to create its debug log file.
Note: The Java Applet
is built with Java version 1.5.
Therefore, the target user must have a browser Java plug-in of version 1.5 or later for the Java applet to run correctly.
