Configure LDAP by using the LDAP configuration utility
The LDAP configuration utility contains 4 sections that you can use to configure and test certain LDAP properties to determine the correct values for your requirements.
- Connection
- Group search
- User search
- Other settings
You must complete section 1 in the utility before you can access and use the remaining sections.
To access and run the utility select .
The LDAP configuration utility is displayed.
