Specifying an IP address for a windows target
Use the, LocalIPInterface, property to specify the IP address that the Windows target will use for connecting to the Remote Control server.
Modify this parameter within the Windows® registry by completing the following steps:
- At a command prompt type regedit.
- Navigate to \HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\BigFix\Remote Control\Target
- Right-click LocalIPInterface and select Modify.
- Enter the required IP address in the Value data field and click OK.
- Restart the target service.
