Testing your Microsoft Entra ID connection
The first step is to test that you can successfully connect to Microsoft Entra ID. This section of the utility must be completed and verified before you can continue. To test your Microsoft Entra ID connection, complete the following steps:
Enter the connection information.
- Client ID
- Defines the Client ID used to establish a connection to Microsoft Entra ID.
- Tenant ID
- Defines the Tenant ID used to establish a connection to Microsoft Entra ID.
- Secret
- This must be set to the secret defined for authenticating. You can
enter a plain text or an encrypted secret. If you enter a plain text
secret, you can encrypt it by clicking Encrypt Password. Note:When you click Encrypt Password, Secret Encrypted is automatically selected. If you enter an encrypted secret, you must also select Secret Encrypted.
- Secret Encrypted
- Determines whether the secret is treated as encrypted or not. If you
select Secret Encrypted, the password is
treated as encrypted and if you do not select it, the password is
treated as plain text. Note:
- This option is automatically selected when you click Encrypt Password.
- If you enter an encrypted secret in the Secret field and deselect Secret Encrypted, the password is not decrypted. The password remains encrypted for security reasons.
- Azure Authority Host
- Specifies the Azure Authority Host to use. The value of the property
is one of the following strings:
- https://login.microsoftonline.com/ (Public Cloud)
- https://login.microsoftonline.us/ (US Government)
- Click Test Connection.
After you have a successful connection to Microsoft Entra ID, you can then configure and test group and user search parameters.
