Configure Microsoft Entra ID by using the configuration utility
The Microsoft Entra ID configuration utility contains four sections that you can use
to configure and test certain properties to determine the correct values for your
requirements.
- Connection
- Group search
- User search
- Other settings
You must complete section 1 in the utility before you can access and use the remaining sections. To access and run the utility select .
The Microsoft Entra ID configuration utility is displayed.
