Global Settings
Use the Global Settings dialog in BigFix Power Management to configure international currency and weight units for your deployment. These settings affect how energy costs and consumption values are displayed across all power reports and dashboards.
The Global Settings option on the Manage Custom Assumptions Wizard
In this dialog, you can set international currency and weight units for your deployment.
Currency Unit drop down in Global Settings dialog box
Expanded Currency Unit drop down list in Global Settings dialog box
After making a selection from the drop-down lists, click Update Settings.
