Enable Wakeup
The Enable Wakeup feature activates the Wake-on-LAN Medic Utility, which wakes computers according to a defined schedule and also sends wake-up requests to Last Man Standing computers. To set up the Wake-on-LAN Medic Utility, ensure that BESWolMedic.exe version 1.5.30 or later is used and that RESP API is correctly configured on a BigFix server version 9.0 or later to avoid network security warnings.
Enable Wakeup includes a task for enabling the Wake-on-LAN Medic Utility. This utility is used to wake computers based on the schedule defined in the Schedule Wake-on-LAN wizard. It also sends a wake-up request to any Last Man Standing computers that are shut down.
Enable Wakeup task in the BigFix Power Management navigation tree
In addition to the BigFix Wake-on-LAN technology, BESWolMedic.exe version 1.5.30 or later uses a directed broadcast that does not require Wake-on-LAN forwarders or Last Man Standing computers.
To enable the Wake-on-LAN Medic Utility, click the Enable task in the List Panel, and then click in the Actions box of the Task window.
Ensure that RESP API is set up correctly to avoid errors and for the Wake-on-LAN Medic Utility to function properly. RESP API is supported by BigFix server version 9.0 and later.
Actions box in the Enable Wakeup task window for deploying the Wake-on-LAN Medic Utility
When the utility runs for the first time, the BigFix Server firewall may trigger a network security warning. If network access is not approved, no directed broadcast is issued. The existing BigFix Wake-on-LAN technology will continue to work.
